Date/Time: Wed, 25 Nov 2026 16:25:16 +0000
removing study names from chart header
View Count: 843
| [2025-10-13 11:24:00] |
| User181801 - Posts: 47 |
https://www.sierrachart.com/image.php?Image=1760354491742.png Hi and thanks for your help. In the chart header I want the chart symbol and interval but not the names of the studies. Is that possible? I only have "symbol-period-chart#" enables in the chart header customization. |
| [2025-10-13 17:52:23] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes you can do that. Refer to: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-13 17:52:44
