Date/Time: Wed, 25 Nov 2026 16:15:18 +0000
[Programming Help] - DTC Server Connection Issue - Immediately Disconnects
View Count: 434
| [2025-10-12 21:29:49] |
| User118180 - Posts: 1 |
Hello Support, I am attempting to connect to the DTC Server on my local machine, but all connections immediately close. Here are the details: Sierra Chart Version / Package: Integrated Standard 10 DTC Server Port: 11099 Connection Method: Localhost (127.0.0.1) Symptoms: Telnet to 127.0.0.1:11099 closes immediately Node.js socket connection to the DTC server connects briefly but then disconnects Could you please advise whether my current package supports DTC Server connections, and if so, what settings are required to allow local connections? Thank you for your help. Best, Daniel |
