Date/Time: Wed, 25 Nov 2026 16:15:19 +0000
X Axis not displaying
View Count: 402
[2025-10-10 18:25:02]
mlurski - Posts: 7
Hi
I cant get the right axis to display price.
Can you please help
https://www.sierrachart.com/image.php?Image=1760120123588.png
[2025-10-10 19:03:50]
Your subject refers to the X-Axis, so if you are referring to the Time Scale, then check the following setting:
Chart Settings: Hide Time Scale (Chart >> Chart Settings >> Scale menu))
Also, it could be a coloring issue, so check the following as well:
Graphics Settings: Chart Time Scale Text Color
If you are referring to the Price Scale, then you most likely have the color of the prices set to be the same as the background (white). Refer to the following:
Graphics Settings: Chart Values Scale Text Color
Date Time Of Last Edit: 2025-10-10 19:06:40
[2025-10-10 19:42:07]
mlurski - Posts: 7
yes, it was the text color
thanks, John
