Date/Time: Wed, 25 Nov 2026 16:15:20 +0000
One way Linking between charts
View Count: 506
[2025-10-09 20:55:09]
masedi - Posts: 63
Hi team,
I have liking configured between some charts but I am facing an issue since the sync is 2 way.
My requirement:
Base Chart A -> trade window/studies/days to load should be applied to several other charts B,C,D
On chart B,C,D I want to add additional studies on each. But when I make any changes, the changes get synced back to all the other charts
From the documentation: Chart Settings: Linking
I wasnt able to understand how to achieve that. I believe I need to use master mode, but on which chart?
[2025-10-09 21:25:58]
There is not a way to share only some studies and not others. For instance, you can not add 2 studies to chart A, have those show on Charts B, C, and D, and then add additional studies to charts B, C, and D, and not have those studies show back up on Chart A. You will either need to share all the studies, or none.
To share none of the studies, then do not set the linking for Studies.
The Master Mode allows you to share some linking options between charts but not others. For instance, if you want the following:
- Trade Window: Charts A, B, C, D
- Days to Load: Charts A, B, C, D
- Studies: Charts A, B
Then you would need to set Master Mode on Charts C and D to prevent them from modifying the studies for charts A and B.
