Date/Time: Wed, 25 Nov 2026 16:15:20 +0000
Subject: Chart Not Updating in Real Time Despite Data Feed Connection
View Count: 619
[2025-10-09 14:41:27]
User759759 - Posts: 6
Hello Sierra Support Team,
I’m experiencing a persistent issue where the price updates in the chart header (real-time quote), but the candles on the chart do not move or update — they remain frozen in an earlier part of the session.
I’ve already tried all the following steps with no success:
Verified that I’m connected to the data feed (File → Connect to Data Feed).
Checked Session Times in Chart Settings — they are correct for ES (CME hours).
Confirmed that Chart Replay / Chart Frozen modes are not active.
Set Chart Update Interval to 250 ms under Global Settings.
Deleted and re-downloaded all chart data (Edit → Delete All Data And Download).
Restarted Sierra Chart completely.
Despite all this, the chart remains stuck — price moves in the quote header, but no new bars print.
Could you please help me identify what might be causing this issue?
I’m attaching a screenshot showing the situation (price moving, chart not updating).
Instrument: ESZ25 (E-mini S&P 500 Futures)
Chart Type: Volume and TPO Charts
Feed: CQG / Denali (please specify which you use)
Version: (write your Sierra version, e.g. v2554)
Thank you for your assistance,
Best regards,
Date Time Of Last Edit: 2025-10-09 14:43:29
imageScreenshot_911.png / V - Attached On 2025-10-09 14:43:20 UTC - Size: 154.03 KB - 219 views
[2025-10-09 14:47:00]
Refer to the following for the things to check:
