Date/Time: Wed, 25 Nov 2026 16:15:18 +0000
ETH futures - [CV-D] [M] - Cannot display continuous
View Count: 400
| [2025-10-09 09:32:56] |
| Le Dharma - Posts: 86 |
Hey Sierra, I'm looking to remove the disabled portion, so I can see the continuous contract of the ETH futures contract on the CME exchange. I've tried deleting and redownloading the data, but nothing happens. Can you guys help me figure out how to display the full continuous data? I'm using version 2715. |
| [2025-10-09 16:45:20] |
What is the exact symbol you are using for the chart. We need what is entered in "Chart >> Chart Settings >> Symbol >> Symbol". Also, we highly recommend updating to the latest version. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-10 01:52:12] |
"ETHV25-CME" or "ETHV25-CME [CV-D][M] 120 Min"
| [2025-10-10 15:29:20] |
There is no particular reason that you should have an issue with that symbol. Please update to the latest release so we can make sure that there isn't something else going on related to changes that have been made that may be causing this. Follow these instructions to update: Software Download: Fast Update Let us know if you continue to get the [CV-D] symbol after you update. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
