Date/Time: Wed, 18 Nov 2026 09:39:49 +0000
Up Bars Only
View Count: 497
[2025-10-07 13:12:29]
User847587 - Posts: 23
Is there a study that will display/separate Up bars only?
[2025-10-07 13:39:22]
Tony - Posts: 733
couple things need to be clarify:
1, what is the definition of up bars?
2, do you want all non-up bars removed or simply not being displayed and with gaps left?
[2025-10-07 14:50:11]
1. Up bar is close greater than open. Down bar is reverse. Close less than open.
2. I don't think it matters to the analysis. So, not displayed.
[2025-10-07 16:05:05]
Tony - Posts: 733
I am not aware of existing studies to do that.
It might be able to achieve by spreadsheet that I have no knowledge, we will wait Sierra or other users' feed back.
With ACSIL, you could hide the Main Graph first:
Chart -> Chart Draw Type -> Blank
and have 2 subgraphs as Bar Top and Bar Bottom (skip zeros), the condition to draw any bar is "Open is lower than Close":
for (int IndexCount {0}; IndexCount<=sc.Index; IndexCount++) {
if (sc.Open[IndexCount] < sc.Close[IndexCount]) {
MyBarTop[IndexCount] = sc.High[IndexCount];
MyBarBottom[IndexCount] = sc.Low[IndexCount];
else {
MyBarTop[IndexCount] = 0.0;
MyBarBottom[IndexCount] = 0.0;
Date Time Of Last Edit: 2025-10-07 16:06:54
[2025-10-07 16:39:00]
Use the "Color Bar Based on Alert Condition" to color the Down bars the same as the background. Refer to the following:
Your actual condition would be the following:
=C < O
