Date/Time: Wed, 25 Nov 2026 16:15:14 +0000
Is it possible on Sierra to have two volumes profiles for the session side by side ?
View Count: 541
| [2025-10-07 12:30:04] |
| User833419 - Posts: 1 |
Hello, I would like to have for the session two different volume profiles one for volume by price and one for delta volume profile, in the image attached you can see they are overlapped, i want them side by side, is this possible ? |
| Attachment Deleted. |
| [2025-10-07 14:52:34] |
It is not possible to have them side-by-side within the data for the period, such as you are showing in your images. The only way to have them side-by-side is to have them for 1 period and have them on the right-side of the chart. Refer to the following: Volume By Price Study: Allow Side-By-Side Profiles on Right Side For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
