Date/Time: Wed, 25 Nov 2026 16:15:16 +0000
Double click chart tab to Restore Window
View Count: 387
| [2025-10-07 00:54:27] |
| User629461 - Posts: 213 |
I use the double click chart tab to Maximise the chart window all the time but to Restore the window is fiddly trying to click the Restore button in the top right corner. Is there an option to dbl click the tab to Restore instead? If not, would this be difficult to add?
Date Time Of Last Edit: 2025-10-07 00:56:31
| [2025-10-07 13:50:44] |
| Sierra_Chart Engineering - Posts: 25481 |
If you right-click on a Chart tab there is a Restore command.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-07 13:50:53
