Date/Time: Wed, 25 Nov 2026 16:15:18 +0000
Commissions missing
View Count: 392
| [2025-10-06 19:14:09] |
| florianh - Posts: 19 |
Hello, I´m trying to configure FDXS symbol via Eurex. Order routing goes via CQG at Stage 5 broker. I use your Denali + Eurex feed correctly. Im having trouble setting up the commissions. They are setup correctly as round turn commmission in Global Symbol Settings value 0.95 and also in the Trade Activity Log its set to Use Commission. I noticed that the symbol doesn´t show a currency or commission by default, so I entered 0.95 and tried USD or EUR or nothing. Either way commissions don´t show up in Trades activity log. extra question, is it correct that Sierra Chart shows always USD as account currency? Or should my broker adjust this at their end to EUR? thank you for your help! |
| [2025-10-06 21:05:55] |
Refer to the information at the following link: Trade Activity Log: Use Commission Also, make sure that on the "Global Symbol Settings" the option for "Use Custom Symbol Settings Values" is enabled, or the commission will not show in your Trade Activity Log. Refer to the following: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) If you are not seeing the Commision in the Profit/Loss on the Trade Statistics, Trades, or Period Trade Statistics, after going through the above, then we would need to know what value you are seeing for one trade and the symbol of that trade. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
