Date/Time: Wed, 25 Nov 2026 16:15:03 +0000
Downloading Market Depth for Micro-Ether futures (MET)
View Count: 407
| [2025-10-06 18:33:15] |
| User713524 - Posts: 3 |
Hi there. When I click "Download Depth Data from Date-Time" on my METV25 (or other MET) chart, nothing happens. I did double check to make sure the "Record Market Depth Data" option was set for MET. This functionality worked fine for 12 other symbols (GC, ES, MBT, etc). I just wanted to check if this is supported for MET, or if perhaps I'm doing something wrong. Thanks! Gary |
| [2025-10-07 16:47:44] |
| Sierra_Chart Engineering - Posts: 25481 |
We needed to add support for historical market depth data for this symbol. This is completed, but will not go into effect until over the weekend. Also: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-10-07 16:50:53
