Date/Time: Wed, 25 Nov 2026 16:15:14 +0000
[User Discussion] - RTH missmatch XAV?
View Count: 454
[2025-10-04 15:16:12]
Dennzisme - Posts: 32
I’ve noticed a discrepancy with the ‘XAVH25_FUT_CME’ symbol. It appears to open at 12:30 rather than 13:30 (UTC+0). Is this a data mismatch, or is there another reason for the earlier open?
Attached is the .txt file (snippet of it) I exported from Sierra Chart via Edit > Export and Edit Intraday Data.
2025/3/12, 19:59:52.021, 145960.0, 145970.0, 145960.0, 145960.0, 1, 1, 1, 0
2025/3/12, 19:59:53.409, 145980.0, 145980.0, 145940.0, 145980.0, 1, 1, 0, 1
2025/3/12, 19:59:55.751, 145960.0, 145960.0, 145910.0, 145960.0, 1, 1, 0, 1
2025/3/13, 12:30:18.271, 145280.0, 148210.0, 145280.0, 145280.0, 1, 1, 1, 0
2025/3/13, 13:02:29.364, 145370.0, 147140.0, 145370.0, 145370.0, 1, 1, 1, 0
2025/3/13, 13:31:54.132, 145660.0, 145660.0, 145600.0, 145660.0, 1, 1, 0, 1
2025/3/13, 13:31:55.685, 145620.0, 145900.0, 145620.0, 145620.0, 4, 1, 4, 0
2025/3/13, 13:31:55.685, 145620.0, 145900.0, 145620.0, 145620.0, 3, 1, 3, 0
imagesierra chart.png / V - Attached On 2025-10-04 15:12:09 UTC - Size: 17.08 KB - 209 views
[2025-10-05 22:03:01]
Sierra_Chart Engineering - Posts: 25481
This is an infrequently traded contract, and all of the data that you see in the chart, assuming you have the full session times set, is all of the data there is. Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings
Date Time Of Last Edit: 2025-10-05 22:03:09
