Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
Sierra Chart Zoom in issues
View Count: 502
| [2025-10-02 13:23:32] |
| User15952 - Posts: 137 |
Please see attached images; everything is zoomed in. I cannot find the issue. Thanks |
| [2025-10-02 17:03:20] |
These are controlled through the Font settings in "Global Settings >> Graphics Settings >> Fonts". The Message Log and Open Chartbook window are controlled through the setting for "Text Windows". Refer to the following: Graphics Settings: Text Windows The Control Bar text size is controlled through the setting for "Control Bar Text". Refer to the following: Graphics Settings: Control Bar Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
