Date/Time: Wed, 25 Nov 2026 16:15:09 +0000
[Programming Help] - ACSIL: Flip Vertical (Gann Fan)
View Count: 578
| [2025-10-02 11:22:06] |
| User688525 - Posts: 403 |
Hello Sierra Chart, Is it possible to flip a drawing (Gann Fan) vertically (Flip Vertical) with ACSIL? This is currently available using the right-click menu, but I don't see any documentation to do using ACSIL? Thank you |
| [2025-10-02 16:39:02] |
There is not an option to do a "Flip" on the anchors through ACSIL. But the reason for this is that when the button is selected the anchors themselves are changed to perform the flip. Therefore, you can do this yourself by calculating the appropriate anchor points and changing them. Refer to the following: Using Drawing Tools From an Advanced Custom Study: s_UseTool::EndValue For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-02 20:26:38] |
Hi John, Thank you! Cheers! One question: Can Gann Fan angles/percents be specified via ACSIL? Date Time Of Last Edit: 2025-10-02 22:16:44
| [2025-10-03 11:14:57] |
Hi John, I figured out the Gann slopes and retracements. For the Gann Fan tool, how are the following configured using ACSIL: - Show Labels - Draw Labels at Line End On another note, with the Time Extension study, the scsf_UseToolExampleDrawingTimeExpansion has been helpful, however, is there a way to configure the visibility, color, etc., for following levels in the Time Expansion tool using ACSIL: - Level 1 (Trend Line) - Level 2 (Time Line) - Level 3 (Base Level, 0%) - Level 4 (Base Level, 100%) Thank you Date Time Of Last Edit: 2025-10-03 11:20:54
