Date/Time: Wed, 25 Nov 2026 16:15:08 +0000
Issue: Label Text Double Spacing
View Count: 431
[2025-10-02 11:04:10]
User688525 - Posts: 403
Hello Sierra Chart,
I have noticed that a double space is added between label text and price if price is set to display.
See the attached where there is a double space between "Sample Text" and the price. How can this be removed?
Thank you
imageSierra Chart Double Spacing.png / V - Attached On 2025-10-02 11:02:22 UTC - Size: 18.39 KB - 181 views
[2025-10-02 11:07:25]
User431178 - Posts: 910
Disable the price display and instead enter it as part of the text string, then you have control over the spacing.
[2025-10-02 16:34:50]
How are you displaying the text and price? Is this a drawing or a subgraph using Labels? or Something else?
[2025-10-02 20:26:09]
Hi John,
In order of appearance, the drawings and settings are:
- Extended Rectangle (Show Price Labels, Right Text/Label Alignment)
- Rectangle (Show Price Labels, Right Text/Label Alignment)
- Horizontal Ray (Show End Price Point, Right Text/Label Alignment)
- Horizontal Line (Show End Price Point, Right Text/Label Alignment)
Date Time Of Last Edit: 2025-10-02 20:29:11
[2025-10-02 21:40:09]
There is a double space between the text and the price when the items are right-aligned. This is hard-coded in the system and there is not a way to change this.
We do not want to change how it is setup in the system, as this is how it is has been for a long time and it would be more frustrating for people that are used to it to have it changed than the other way around.
[2025-10-02 22:15:55]
Hi John,
Thanks for investigating and confirming.
Cheers!
