Date/Time: Wed, 25 Nov 2026 16:25:10 +0000
Trade Window issue
View Count: 566
[2025-10-01 17:09:33]
User98657 - Posts: 420
SC,
I'm having an issue with my Trade Window. When detached from the chart the title bar is off screen and the window cannot be moved. I can attach to the chart, and unattach, and that's all.
I found a previous issue with this and have gone to Global Settings>>Tool Settings >> General - Chart Values and set all three of those selections to No, restared SC, and it hasn't changed.
[2025-10-01 19:40:32]
Select "Chart >> Reset Child Windows". Refer to the following:
Chart Menu: Reset Child Window (Chart menu)
[2025-10-01 20:20:36]
Ugh!
Thanks John.
I totally misread that post.
[2025-10-09 12:49:26]
cfuture - Posts: 86
I have the same problem and even though I have reset the child windows, I keep having the same problem. This can be somewhat a nuisance when havingg many chartbooks open at one time.
[2025-10-09 13:41:33]
Sierra_Chart Engineering - Posts: 25481
If you keep having the same problem, then the Trade Window is getting moved by the operating system or some other reason for moving but it is not Sierra Chart moving it.
Date Time Of Last Edit: 2025-10-09 13:41:57
[2025-10-10 15:44:33]
cfuture - Posts: 86
I have the same problem on my laptop which runs win11 and desktop which runs win7 pro
[2025-10-10 15:57:55]
If resetting the windows does not resolve it, then do an Internet search for "moving windows that are off screen". There are plenty of postings on this topic and how to move the window back.
[2025-10-11 23:06:16]
cfuture - Posts: 86
Maybe it would be best if I clarified further as to the attached trade window being offset and overlapping the first level control bar after opening a chartbook. Does that change anything as far as a solution?
[2025-10-13 15:14:14]
Please get us an image of what you are seeing by following these instructions:
