Date/Time: Wed, 25 Nov 2026 16:03:10 +0000
Merge Profile
View Count: 478
| [2025-10-01 15:53:14] |
| paolopens - Posts: 23 |
I made a TPO market profile daily. and merge it until it goes into monthly. the red box outline is the current month. and the white box outline is the previous month. everytime i close sierra chart it goest back to daily TPO charts and i have to merge it manually to become monthly. is there a setting once a merge all the charts into monthly and when i re-open sierra chart it shows monthly chart autmatically with merged profile. I want it to be fixed when i merge the profiles even i close sierra chart and re-open
| [2025-10-01 15:56:02] |
Marges and splits of the TPO profiles are kept when saving the chartbook. So you should not be having an issue with this. The only thing we can think of is that the chartbook is not saved after you merge the profiles together. Be sure to save the chartbook before you close out of Sierra Chart. If you continue to have an issue, then please get us the chartbook that contains that chart and we will see if we can reproduce it from your chart. -- Separately, if you are wanting Monthly TPOs, then you can set this in the TPO Inputs rather than merging the Daily TPOs together. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Profile Time Period Length For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
