Date/Time: Wed, 25 Nov 2026 16:03:03 +0000
Is there a way to overlay columns on top of each other on the DOM?
View Count: 388
[2025-09-30 13:38:08]
xORDERBOOKx - Posts: 191
I'm trying to compress the size of my DOMs. I want the trade information (SL, TP, and current fill price) to be flush with the buy column, even if it overlays the "Current Traded Total Volume." Right now the Current Trade Total Volume is blocking the way. I'm assuming it's because these things are in their own respective columns.
I have attached a screenshot.
Is there any way to accomplish this?
Thank you.
Date Time Of Last Edit: 2025-09-30 14:26:16
imageES DOM.png / V - Attached On 2025-09-30 13:38:00 UTC - Size: 33.58 KB - 185 views
[2025-09-30 15:10:47]
The best you can do is to change the order of the columns in the DOM so that the Buy column is furthest to the Left and then the order lines will be right next to it. Refer to the following:
Global Trade Settings Windows: Move Up/Left (Trade >> Customize Chart/Trade DOM Columns)
[2025-09-30 15:11:49]
Thank you.
