Date/Time: Wed, 25 Nov 2026 16:03:01 +0000
SC2798 withdrawn from release?
View Count: 436
[2025-09-30 12:31:03]
User512353 - Posts: 198
On 2025/09/27 SC2798 was made available on the download webpage as "Current version: 2798 (September 25, 2025)".
On 2025/09/28 SC2789 was visible again as "Current version: 2789 (September 1, 2025)".
What is the status now of the current release??
Is 2798 the latest stable version or 2789?
It should be communicated more clearly if any release is being withdrawn.
[2025-09-30 14:00:36]
Sierra_Chart Engineering - Posts: 25481
The concept of a stable versus unstable version, does not exist and we cannot answer anything in that regard. All versions are considered stable.
The latest version is available is a pre-release. And it is stable.
Date Time Of Last Edit: 2025-09-30 14:01:38
[2025-09-30 14:11:52]
This is confusing - and certainly not aligned with common practices in the IT world.
What is the status difference between the "Current Version" and the "PreRelease Version" (as labeled on the download page) then??
[2025-09-30 15:17:27]
We do not know what may have occurred with the version number for the Current Version, and it is something that we will bother to dig into. If it was accidentally changed to the wrong version for a bit, then we apologize.
As to the difference between the Current Version and the Pre-Release, refer to the following:
Software Download: About Prereleases. Are they Stable?
