Date/Time: Wed, 25 Nov 2026 16:03:06 +0000
DOM Data Limiting stopped working
View Count: 438
| [2025-09-30 00:24:48] |
| User246578 - Posts: 87 |
Updated to ver 2799 Set DOM Data Limiting <= 699 DOM studies VBP Total Volume is not filtering at all by showing all of the volumes. |
| [2025-09-30 14:26:07] |
What is "DOM Data Limiting"? What setting exactly is this?
| [2025-09-30 16:49:55] |
DOM>Click on Chart Menu>Chart Settings>Data Limiting>Exclude<= Exclude<=#(let's say #= 600) must effect Total Volume set by Study's VBP |
| [2025-09-30 18:01:46] |
We are not seeing any issue with this. When we set the option for "Exclude <=" to 600 for an ES chart or Trading DOM, the Volume by Price profile goes away, as there are no trades larger than 600. If you are setting this on a Trading DOM, then be sure you are selecting "Chart >> Chart Settings" for that actual trading DOM. If the DOM is not attached to the main Sierra Chart window, then you need to access the settings through the trading DOMs menus (Chart >> Chart Settings). You can not do it from the main window, as that will affect a different chart. If you are still having an issue, then please get us an image of the window with the Volume by Price profile on it with the filtering set as you want it. Also, please tell us the exact setting you have set and the value (i.e. "Exclude <=" set to ###). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-30 20:30:59] |
Updated to version 2800 and the issue is gone. Thx |
