Date/Time: Wed, 07 Oct 2026 11:30:38 +0000
Change Color of Chart DOM $ values
View Count: 590
[2025-09-29 18:14:45]
User794005 - Posts: 51
Hello I changed the background to white and because of that I had to change the chart values on the right chart to black to display them. I then added DOM Chart but then the values changed to white color. Could you help me change their color to black?
imageScreenshot 2025-09-28 at 8.49.10 PM.png / V - Attached On 2025-09-29 18:14:36 UTC - Size: 886.46 KB - 308 views
imageScreenshot 2025-09-28 at 8.49.01 PM.png / V - Attached On 2025-09-29 18:14:40 UTC - Size: 874.25 KB - 277 views
[2025-09-29 18:14:57]
John - SC Support - Posts: 48127
Refer to the following graphics setting:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Values Scale Text
[2025-10-02 14:10:55]
I am sorry but I have tried and changed colors of every single line that starts with 'Chart DOM' in the Graphic settings.Still no luck changing the $ values on the scale. I am confused and a little frustrated. Any help is appreciated
imageScreenshot 2025-10-02 at 9.10.15 AM.png / V - Attached On 2025-10-02 14:10:28 UTC - Size: 209.4 KB - 244 views
[2025-10-02 17:41:57]
You need to change the color of the "Chart DOM Values Scale Text".
If you are changing this color and it is not working, then most likely you are not changing the item in the correct location. There are both Global and Chart specific graphics settings. So if it is not working in one, try the other. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
