Date/Time: Wed, 25 Nov 2026 16:15:09 +0000
SG8 and SG9 in Number bar calculated values
View Count: 574
| [2025-09-29 18:01:54] |
| User749673 - Posts: 28 |
Maximum Ask Volume Bid Volume Difference (Ask Volume Bid Volume Difference High) (Max Ask Vol-Bid Vol): During the formation of each chart bar, as it is built from the tick by tick data, the difference between the Ask traded volume and the Bid traded volume is calculated. The Maximum Ask Volume Bid Volume Difference is the maximum value of this difference which existed during the formation of the chart bar. This value is also used in many of the other Numbers Bars Calculated Values Subgraphs. Minimum Ask Volume Bid Volume Difference (Ask Volume Bid Volume Difference Low) (Min Ask Vol-Bid Vol): During the formation of each chart bar, as it is built from the tick by tick data, the difference between the Ask traded volume and the Bid traded volume is calculated. The Minimum Ask Volume Bid Volume Difference is the minimum value of this difference which existed during the formation of the chart bar. This value is also used in many of the other Numbers Bars Calculated Values Subgraphs. Dear Team I need to access the price level at which this max SG8 and min SG9 value touches in number bar .Is there any provision to access this through ACSIL codes ? Your timely help will be much appreciated Thanks |
| [2025-09-29 18:09:05] |
The "Maximum Ask Volume Bid Volume Difference" and "Minimum Ask Volume Bid Volume Difference" is not calculated on a per price level basis. This is the entire bar Ask Volume Bid Volume Difference. So there is no specific price point at which this occurs. If you want to find the Min and Max Ask Volume Bid Volume Difference at a price level during the formation of a bar, then you would need to create a custom study and calculate the difference and then store the Max/Min values and the price level and then update as necessary. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-02 18:49:51] |
I am not able to locate price level at which it occurs
| [2025-10-02 20:55:19] |
That information is not available per our response in Post #2. Or are you asking about something else? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
