Date/Time: Wed, 25 Nov 2026 16:15:06 +0000
[Programming Help] - ES NQ Linked Studies
View Count: 426
[2025-09-29 18:01:09]
MarketBeast - Posts: 48
I am using 5-minute charts for ES and NQ with linked studies. My issue is that I'm also using studies, like 'Daily Range Bands' and a 'Price Overlay', which are configured to pull data from the daily chart of each respective symbol.
With the studies linked, this setup isn't displaying the correct data, as the daily reference for one symbol is being applied to the other.
Is there a workaround that would allow me to continue using linked studies? For example, instead of referencing separate daily charts, could I add the daily data as a secondary symbol within the study on my 5-minute chart? I'm not sure if this is a viable solution?
Thank You!
[2025-09-29 18:01:14]
There is no workaround for this. Given what you are trying to do, you would have to not link the Studies between the charts.
[2025-10-12 17:37:41]
Can this be programmed for a fee?
