Date/Time: Mon, 20 Oct 2025 21:39:51 +0000
Renko Chart for Crypto instruments
View Count: 142
[2025-09-29 13:08:15] |
lion323 - Posts: 15 |
How can I setup a Renko chart that is not time dependent on Sierra Chart Like a chart based only the movement on price? Can I aggregate data in sierra for crypto? If so how can I do that? |
[2025-09-29 16:44:44] |
John - SC Support - Posts: 42471 |
Sierra Chart treats all data the same, so it doesn't matter if it is crypto or something else. Therefore, if you want a Renko chart, you just need to select that Bar Period type. Refer to the following: Chart Settings: Bar Period Type (List) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings) We do not know what you mean by "Can I aggregate data in sierra for crypto?" For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-10-11 04:16:07] |
Is DOM data for Binance still available on the advanced package ?
[2025-10-11 19:30:24] |
Sierra_Chart Engineering - Posts: 21166 |
There is no market depth data for Binance. This is not supported.
