Date/Time: Wed, 25 Nov 2026 16:02:54 +0000
Chart Header
View Count: 428
| [2025-09-28 09:02:37] |
| nicktrader - Posts: 817 |
I have had the following problem for a very long time: After I run “Duplicate Chart To Chartbook,” the chart is displayed in the newly created chartbook, but without the “Chart Header". Until now, I have always done it this way to make the chart header visible: I duplicate the chart and then switch to the first chart. Only after switching the chart header is displayed (see pic).No Studies/ Drawings are set. Many thanks |
| [2025-09-29 14:35:00] |
We are not able to reproduce this. What are the exact steps you are taking to duplicate the chart. Please give us the particular settings you are using in the "Duplicate Chart to Chartbook" window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-29 14:49:39] |
I just tried it and it works perfectly. I assume it doesn't work when the stock markets are closed. I'll test it again over the weekend. Many thanks |
