Date/Time: Wed, 25 Nov 2026 16:03:16 +0000
9-25-25 Files to Open on Startup buttons are blank Version 2798
View Count: 427
| [2025-09-27 20:53:30] |
| 4trading - Posts: 22 |
"Files to Open on Startup" buttons are blank in Version 2798 They work to click but are blank with no description. Windows 11, 64-bit, Home Version They have button labels in the prior build 2789. Not a big deal to me, but it is a minor bug. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=127369 |
| Attachment Deleted. |
| [2025-09-28 14:41:14] |
| Sierra_Chart Engineering - Posts: 25481 |
Update to version 2799 to resolve this. It is not a bug. There are new color settings to control the colors of buttons: Files to Open on Startup options are blank | Post: 425945 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-28 19:09:45] |
OK, it looks good in the Pre-release version 2799. Thanks Date Time Of Last Edit: 2025-09-28 19:16:20
