Date/Time: Wed, 18 Nov 2026 09:39:53 +0000
color bar based on alert condition and time filter
View Count: 456
| [2025-09-27 16:42:32] |
| User873130 - Posts: 53 |
Hi is this the correct way to filter signals between 10:30 am ET and 17:00 pm ET? this code is used in color bar based on alert condition study AND (ID60.SG1 > 900, C<O, ID78.SG1>3000,FRACTIME(A3)>=TIME(10, 29, 59), FRACTIME(A3)<TIME(16, 59, 59, 250)) when I use above code, the signal still shows up before 10:30 am ET, what could I be doing wrong? any help is appreciated |
| [2025-09-27 17:31:31] |
| Sawtooth - Posts: 4361 |
You are mixing Spreadsheet syntax with Alert syntax. The Color Bar Based On Alert Condition study uses only Alert syntax. Try this: =AND (ID60.SG1 > 900, C<O, ID78.SG1 > 3000, BARTIME >= TIME(10, 29, 59), BARTIME < TIME(16, 59, 59, 250)) |
