Date/Time: Wed, 25 Nov 2026 16:04:52 +0000
Order Allocation to Trade Accounts Not Visible
View Count: 548
| [2025-09-26 14:15:55] |
| SW Trading - Posts: 7 |
Hello Support Team, I am experiencing an issue with the "Order Allocation to Trade Accounts" option. When I click on it, nothing happens. This is problematic because I have additional accounts linked to this account, and I would like to remove them. As a side note: at the moment, I do not have any live accounts linked, since I currently don’t own one and I am only trading in simulation mode. Could you please advise how to resolve this issue? Thank you in advance for your support. Best regards, Severin Würzinger |
| [2025-09-26 14:56:48] |
Select "Window >> Reset Windows". Then try to open the "Order Allocation to Trade Accounts" again. Let us know if this does not work.
| [2025-09-29 06:52:25] |
No it doesn´t work.
| [2025-09-29 14:15:51] |
| Sierra_Chart Engineering - Posts: 25481 |
We are checking on this. But the command may be Window >> Reset Settings Windows.
| [2025-09-30 11:04:42] |
I’ve already tried that too, but unfortunately it doesn’t help either.
| [2025-09-30 14:10:49] |
We want you to restart Sierra Chart. Do not do anything or open any Chartbooks and then select Window >> Reset Settings Windows. Try opening the Order Allocation to Trade Accounts window again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-30 14:11:23
