Date/Time: Wed, 25 Nov 2026 16:03:22 +0000
SFE data with Sierra Charts with CQG connections?
View Count: 429
| [2025-09-25 00:40:42] |
| User15952 - Posts: 137 |
I will be using package 11; broker is AMP Futures and CQG connection. Is the above still possible? Thank you |
| [2025-09-25 01:36:31] |
| Sierra_Chart Engineering - Posts: 25481 |
Sydney futures? Check with AMP. There are no restrictions from our side regarding this.
| [2025-09-25 01:45:37] |
Thanks, they suggested I post and find out before purchasing the CQG live connection to use with Sierra Charts on package 11.
| Attachment Deleted. |
| [2025-09-25 03:42:45] |
Do not activate the CME Exchange bundle. You do not need that. That market data must come from Sierra Chart through our Denali Exchange Data Feed. If you activate SFE, you should be able to access it in Sierra Chart when using CQG. We do not see an issue with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
