Date/Time: Wed, 25 Nov 2026 21:46:24 +0000
Studies visibility depending on timeframe ?
View Count: 625
[2025-09-24 09:53:25]
User246799 - Posts: 21
Hello, I would like to know if it is possible to set the visibility of the studies depending on the timeframe ?
I mean :
For one single chart, I would like to set a group of studies (study 1, study 2, study 3, 4, 5, 6, 7 for example).
And I would like to see / hide some of these studies depending on the timeframe.
For example : If I set the 5 minute timeframe, I want to see studies 1, 2 and 6 and hide the others.
If I go to the 15 minute timeframe, I want to see studies 2, 3, 4, 5 and hide the others...
Is it possible to do that ? Is it possible to create this possibility please ? (as for the drawings)
Is it possible to create this with the advanced custom study ?
Thank you
[2025-09-24 14:42:59]
There is not a way to do this automatically using the built-in tools. The closest thing would be for you to load a different Study Collection when you change the bar period.
This can be done with a Custom Study by checking the Bar Period and then loading the Study Collection you want based on that. Refer to the following:
ACSIL Interface Members - Functions: sc.ApplyStudyCollection()
[2025-09-24 15:00:13]
Tony - Posts: 738
@User246799 you need write your own study to achieve that with ACSIL.
[2025-09-24 15:02:00]
Ok, thank you for your answer. I'm going to try. Do you think that this is something that you could implement in the future ?
[2025-09-24 15:48:30]
We have noted this as a feature request, but we can not say when we would get to any particular request.
[2025-09-25 14:30:27]
Hello, as discussed above, I have created a custom study that applies on a chart a study collection based on the selected bar period.
But I have a problem !
The problem is that when a new study collection applies after a bar period modification, the previous study collection is not deleted.
The new study collection is added to the previous one again and again --> Big mess !
I don't know how to solve this. Could you please help me ?
Thank you.
[2025-09-25 14:41:38]
You need to post that issue as a new thread and mark it as Programming Help. There is something you are doing that is not correct in your code.
[2025-09-25 15:21:35]
Ok, thank you
[2025-12-09 14:58:09]
No this is not something we would add.
