Date/Time: Wed, 25 Nov 2026 16:03:22 +0000
ZB Future Options
View Count: 465
| [2025-09-23 04:14:54] |
| User841161 - Posts: 357 |
ZP Futures are quoted in 32nds, but ZB options are quoted in 64ths. Is there a way to change y axis to match the quote in 64ths?
| [2025-09-23 15:43:56] |
Change "Chart >> Chart Settings >> Symbol >> Price Display Format" to "1/64". Refer to the following: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-23 17:01:00] |
ok, got it, after also changing Auto-Set to no.
