Date/Time: Wed, 25 Nov 2026 07:56:12 +0000
Highlight Active Chart With Border
View Count: 536
[2025-09-22 18:53:11]
Piotr Grzegorzek - Posts: 36
Can you add a function to Highlight Active Chart With Border?
Tha active chart in a Chart Book is not highlitet when active.
[2025-09-22 18:54:32]
When a chart has the Title Bar displayed, then that will indicate which chart is active, as the title bar changes color based on the Operating System settings.
But, we do understand that if the Title Bar is not displayed, then there is no indicator for which chart is active. We have noted this as a feature request.
[2025-09-23 01:15:09]
GAArtAi - Posts: 9
#2
Hello John,
I hope you’re doing well, and thank you for all that you and your team do in providing us with such a spectacular platform.
I believe the feature request by Piotr above is very valid, and I’m sure many others would find it useful as well.
As you mentioned: “when a chart has the Title Bar displayed, that will indicate which chart is active as the title bar changes color.” This is indeed how I personally use the feature if I really need to quickly confirm which chart is active, then switch back to Tiles mode to maintain a cleaner, less distracting workspace. I truly appreciate having this method as an optional option available.
That said, with Piotr’s request in mind, I was wondering if it might be possible to make the “Highlight Active Chart with Border” as an optional setting in the chart settings, something users can enable or disable depending on their preference.
I completely understand that user preferences can be complex and challenging to balance, but you and the Sierra Chart team continue to deliver what often feels impossible.
Thank you in advance, Team Sierra, for all that you do!
Best!
Date Time Of Last Edit: 2025-09-23 02:15:04
