Date/Time: Wed, 25 Nov 2026 16:03:21 +0000
Cant Download software
View Count: 421
[2025-09-22 17:38:22]
Pgibson821 - Posts: 2
Im getting an error that says " Error saving downloaded files to local system. Stopping installation check log press instal and retry
[2025-09-22 19:40:53]
Do you have proper permissions to install the software to the location you are trying to install it to?
[2025-09-22 23:59:02]
Yes I do, its my personal computer
[2025-09-23 15:37:02]
We really need to see the entire log. Please try to install again, and after it fails select the button in the upper right corner of the window for "Send Log to Support".
Then post in this thread and let us know that you have sent the log.
