Date/Time: Wed, 25 Nov 2026 23:00:19 +0000
Draw Composite Volume Profile Tool - Mirrored Profile
View Count: 827
| [2025-09-22 11:57:18] |
| DonkeyEmporium - Posts: 4 |
Right now with the Volume Profile Draw Tool I'm getting 2x profiles stacked on top of each other - poor visibility/ not clear - see Stacked-Profiles.jpg Using 1x Volume Profile Draw Tool, I need to get 2x profiles to appear on the right - side by side 1x - Total Volume (Aligned Right, Inside Box) 1x - Difference of Bid and Ask Volume aka Delta (Aligned Right, Mirrored Outside Box) See attached Ideal-Profile.jpg for example (I saw the value for "Allow Side By Side Profiles on Right Side ln:62" but appears to only work for profiles stacked on the far right - not what I want to do) How can I create 2x profiles aligned right & mirrored using 1x Draw Volume Profile tool? Date Time Of Last Edit: 2025-09-22 11:59:34
| [2025-09-22 16:36:33] |
There is no way to do what you want. Particularly with the Drawn Volume Profile tool, in which only a single profile is drawn per use. There is no support for drawing multiple profiles. We have noted this as a Feature Request for the Draw Volume Profile tool. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-22 17:25:14] |
Noted. Thanks for clarifying John, I'll look forward to seeing it in an upcoming release of SierraChart |
| [2026-02-10 12:24:40] |
| Asad1939 - Posts: 21 |
Any ideas on when this feature will be implemented?
