Date/Time: Wed, 25 Nov 2026 07:56:03 +0000
Individual Subgraph Transparency
View Count: 601
[2025-09-22 10:38:51]
User688525 - Posts: 403
Hello Sierra Chart,
Can transparency be set for individual subgraphs via ACSIL or another method? I am using "Transparency Level for Fill Styles" on the Subgraphs tab which applies to all subgraphs, however, there are a couple of subgraphs (Extension Lines With Transparent Range) that I would like to change the transparency for without running another instance of the study.
This is a custom study so there is potential flexibility in customizing each subgraph.
Thank you
Date Time Of Last Edit: 2025-09-22 10:40:01
[2025-09-22 16:30:22]
There is just the single transparency level that can be set at the Study level. There is no support for transparency levels for each subgraph.
We have noted this as a feature request.
[2025-09-22 20:27:53]
Thank you, John. Cheers.
