Date/Time: Wed, 25 Nov 2026 16:03:25 +0000
Function sc.SetChartTradeMode() Failed
View Count: 500
[2025-09-22 03:15:49]
Tony - Posts: 738
I am trying to set Chart Trade Mode on and off by ACSIL, but it had no effect.
sc.SetChartTradeMode(sc.ChartNumber, 1);
I get the return value correctly though,
int ReturnValue {0};
ReturnValue = sc.SetChartTradeMode(sc.ChartNumber, 1);
but the function doesn't enable or disable Chart Trade Mode.
Not sure what I missed, thanks so much!
Date Time Of Last Edit: 2025-09-22 03:16:39
[2025-09-22 11:12:23]
Sierra_Chart Engineering - Posts: 25481
Is the study on a Trading DOM type of chart? In which case, it is not going to get disabled.
[2025-09-22 14:08:42]
Tony - Posts: 738
No, the study is not on a Trading DOM type chart, it is on a Range Candle Bar chart.
I tried 5-minute chart as well, same result.
Date Time Of Last Edit: 2025-09-22 14:16:27
[2025-09-24 05:19:30]
This will be resolved in the next release.
