Date/Time: Wed, 25 Nov 2026 07:55:53 +0000
Empty Log Message Window
View Count: 468
[2025-09-20 19:40:09]
mastox - Posts: 2
I'm setting up a new system, I feel really dumb, but I can't seem to get any log messages to the Message Log window. I don't see any from my study or from the HTTP logs.
Attached is a screenshot of my Global Settings >> Log settings
Date Time Of Last Edit: 2025-09-20 19:40:57
imageScreenshot 2025-09-20 152946.png / V - Attached On 2025-09-20 19:36:58 UTC - Size: 34.31 KB - 261 views
[2025-09-21 00:49:54]
seandunaway - Posts: 399
check your global settings -> message categories
imagemessage categories.png / V - Attached On 2025-09-21 00:49:49 UTC - Size: 57.46 KB - 219 views
[2025-09-22 15:57:56]
There were a few releases where the Message Categories were set to "No" by default. This is corrected in the most recent update. So first, update to the current version and see if that resolves it for you. Follow these instructions:
If that does not resolve it fully, then you would need to change the "Message Categories" to "Yes" for the items you want. It is easiest to turn them all on and then remove ones you do not want later. Refer to the following:
Message Categories
