Date/Time: Wed, 25 Nov 2026 07:55:46 +0000
OCO two existing orders
View Count: 437
| [2025-09-18 16:04:25] |
| User181801 - Posts: 47 |
Hello and thanks for you help. I am trying to achieve the following: 1. OCO two limit orders in different symbols. 2. OCO two orders of any type on the same symbol. For instance I put a buy stop and a sell stop in advance and I “connect” them with an OCO. Is that possible? Thank you |
| [2025-09-18 20:01:24] |
| John - SC Support - Posts: 48648 |
1. You open a Limit order for each symbol in its own chart. 2. Enter the order as an "OCO Limit and Stop" (or one of the other OCO order types). Refer to the information at the following link and the 4 items below it: Order Types: OCO Limit and Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
