Date/Time: Wed, 25 Nov 2026 07:55:44 +0000
Issues with setting the symbol session times
View Count: 630
[2025-09-18 15:59:55]
User916167 - Posts: 5
Hi!
I changed the session times in Global Settings → Symbol Settings to avoid having to manually re-enter the session times for all my charts.
However, even after changing the settings in Symbol Settings, when I open a new chart the session times do not match the ones I configured
[2025-09-18 19:59:01]
This should work. Here are the things to check:
- On the Symbol Settings window is the option for "Use Custom Symbol Settings Values" enabled (is there a checkmark next to this option)? Refer to the following:
Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings)
- When you modified the Session Times for a particular symbol, did you enter the times relative to the "Time Zone" that is set in the Symbol Settings? That Time Zone setting is only there to establish the time zone for the Session Times that are entered. Refer to the following:
Global Symbol Settings: Time Zone
[2025-09-19 12:26:33]
I set it like this, but when I open a chart, it opens with these session times
imageScreenshot 2025-09-19 141214.png / V - Attached On 2025-09-19 12:25:45 UTC - Size: 109.82 KB - 198 views
imageScreenshot 2025-09-19 142440.png / V - Attached On 2025-09-19 12:25:57 UTC - Size: 81.14 KB - 252 views
[2025-09-19 14:54:22]
What is your Global Time Zone set to (Global Settings >> Time Zone)?
