Date/Time: Wed, 25 Nov 2026 07:56:05 +0000
TPO Chart
View Count: 527
| [2025-09-17 13:50:34] |
| User400731 - Posts: 2 |
I am facing issue to setting up TPO for stocks please check SS, some empty blocks overlaying https://www.sierrachart.com/image.php?Image=1758116949876.png |
| [2025-09-17 16:10:39] |
| John - SC Support - Posts: 48648 |
You have some other study that is causing that issue. Most likely a Study/Price Overlay. You need to go through the studies on that chart and find the one that is causing it and remove it.
