Date/Time: Wed, 25 Nov 2026 07:56:08 +0000
New Instance opening startup chartbooks from main instance
View Count: 596
[2025-09-16 19:04:20]
kvcornie - Posts: 56
I started a new instance (Instance 2, no other instances exits). When it opens, the Main/Parent instance startup chartbooks opened in it so I deleted them from the Instance 2 "Global Settings/General Setting Startup/Select Files to Open on Startup" and closed the chartbooks in Instance 2 so that no chartbooks were open. Then I saved the instance and closed it.
When I open the new instance again, the startup chartbooks are loaded and are populated in the open on startup menu. I thought the instance operates separately from main instance, but that doesn't seem to be the case in this situation. Please advise.
[2025-09-16 19:09:50]
Disregard, I literally just stumbled on the answer looking for a differnt instance question. Apologies, I promise I searched for the answer first...
