Date/Time: Wed, 25 Nov 2026 07:55:59 +0000
Plotting values from Numbers Bars Calculated Values
View Count: 841
| [2025-09-16 17:29:32] |
| User572973 - Posts: 5 |
Is it possible to directly plot the values calculated in Numbers Bars Calculated Values ? Of course use the Spreadsheet study and then select the columns to output, but I wanted to check if there was a more direct and straightforward way ? Thank you ! |
| [2025-09-16 17:37:49] |
| John - SC Support - Posts: 48648 |
The simplest is to use the "Study Subgraph Reference" and reference the particular subgraph you want and then use an appropriate Draw Style. Refer to the following: Study Subgraph Reference If you want to have control over the number of bars that are calculated, then you could use the "Spreadsheet Formula" and enter the Study ID and Subgraph reference like the following: =ID1.SG1 Where ID1 is the ID of the Numbers Bars Calculated Values Study and SG1 is the subgraph number you want to reference. Refer to the following: Spreadsheet Formula Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-16 18:21:08] |
this works, thank you
