Date/Time: Wed, 25 Nov 2026 07:56:11 +0000
Single weekly Volume by Price study
View Count: 650
| [2025-09-14 22:49:03] |
| User792664 - Posts: 5 |
Is there a way to draw a single VbP current weekly profile (starting with Sunday globex open), which will automatically update at the start of each week? I'm currently using "From Start Date-Time + Fixed Time Length" but I have to update the start date every week. |
| [2025-09-15 15:20:32] |
| John - SC Support - Posts: 48648 |
What you are doing now is the way to do it for a single profile. Another option would be to use the "Multiple Profiles Based on Fixed Time", as this would give you the most recent profile as you want it. But you would end up with the other profiles on the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-17 03:53:15] |
Thank you for confirming. Can I propose a feature request that functions like any of the "From Start Date-Time" options, but instead of a specific start date, it starts with the most recent specified day of the week (e.g. Sunday) and, in this example, would reset every Sunday. |
| [2025-09-17 10:38:04] |
| Tr00pz - Posts: 32 |
You can use the following settings to accomplish what you are looking for: Volume Graph Period Type - One Period from Most Recent Period Start to End Time Period Type for Fixed Time - Weeks Time Period Length for 'Fixed Time' - 1 This will start a volume profile every Sunday at open for the week. |
| [2025-09-17 15:12:47] |
Our apologies - the option that Tr00pz mentions will work. We were thinking something else related to this.
| [2025-09-17 17:55:10] |
Thank you, Tr00pz. That works for the current week! I'm guessing there is no way to do the previous week - i.e. prior week (single) profile from Sunday open to Friday close that resets automatically each week. |
| [2025-09-17 21:46:04] |
To get the previous week, you would have to enter the dates. The "Periods back to Reference" does not apply with the option for "One Period from Most Recent Period Start to End".
