Date/Time: Wed, 25 Nov 2026 07:56:11 +0000
Historical Data Missing
View Count: 506
[2025-09-12 22:24:37]
User871314 - Posts: 32
Hi, I am trying to export historical data for ESM5 from March until June 2025 but the historical download stops at 4.3.25 for some reason. I have the data limiting by date range and this works for other date ranges just not between 4.3.25 and 6.14.25.
I have attached the log file.
attachmentlog.txt - Attached On 2025-09-12 22:24:16 UTC - Size: 49.81 KB - 225 views
[2025-09-15 13:55:14]
You can only export what is already in your system. So if you do not have the data for that time frame, then you will not be able to export it.
Open a chart for that symbol and then make sure you have the data covering the time period you want. If the data is not downloading for the most recent trading for that symbol (i.e. June 2025) then follow these instructions:
