Date/Time: Wed, 25 Nov 2026 07:55:58 +0000
Multiple Charts on Chart/Slice
View Count: 701
[2025-09-12 13:45:58]
RockyTheRescue - Posts: 31
This is a basic question and I apologize in advance but maybe I am not using the correct search terminology.
I want to create four separate charts on one page. I am not trying to overlay four symbols on one chart, but diving the page into quarters to show a separate chart in each quarter. I want to track ES, NQ, YM and RTY on the same page to see all the movements at once.
Can that be done - thanks in advance.
[2025-09-12 16:08:57]
You can do this a couple of different ways. In each case, you need to have 4 charts open each with the respective symbol you want.
Option 1: If you want to keep the charts within the main Sierra Chart program, then when you have the 4 charts open in a chartbook, select "Window >> Tile as Grid - Horizontally". Refer to the following:
Window, CB and CW Menus: Tile as Grid - Horizontally (Window)
Option 2: If you do not want the charts contained within the main Sierra Chart program, then go to each chart and with it active select "Window >> Detach Chart Window".
Once all the charts are detached, then setup them up how you want them on your desktop.
Window, CB and CW Menus: Detach/Attach Window (Window)
[2025-09-12 16:28:16]
Thanks for your response - maybe I am not being clear or misunderstanding you. I want to see four charts on one page. So they would appear in four little squares on the same page so I can watch price movement of each security at the same time. Does that make sense?
[2025-09-12 17:19:51]
There is not a way to do what you want within a single chart. Therefore we gave you the options for how to do this using 4 charts.
There is the ability to view multiple symbols on a single chart, but they will be in different regions, therefore they would show horizontally. There is not a way to get this setup in 4 quadrants. But if you are interested, the way to do this is to use the "Add Additional Symbol" study. Refer to the following:
