Date/Time: Tue, 03 Nov 2026 15:49:58 +0000
MA Alert Formula
View Count: 1810
| [2014-10-10 15:30:27] |
| User765038 - Posts: 22 |
Hi SC, I have a moving average study on my chart. What is the formula to set in the condition box of the alert tab so that an alert is activated as soon as price action touches the moving average? Thanks and regards, Rod |
| [2014-10-10 16:26:33] |
Try: =AND(SG1 <= H, SG1 >= L) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-10-31 15:56:43] |
Thanks, works well. How should this formula be amended to add the condition "+/- 2 pips". Appreciated. Regards, Rod Date Time Of Last Edit: 2014-10-31 16:34:57
| [2014-11-02 03:09:09] |
| cmet - Posts: 743 |
Rod, You might use the TICKSIZE syntax. =AND(SG1 <= (H + 2*TICKSIZE), SG1 >= (L - 2*TICKSIZE) |
