Date/Time: Wed, 25 Nov 2026 21:46:00 +0000
Spreadsheet only updates when a fill happened, not continuously
View Count: 552
| [2025-09-11 18:04:45] |
| Andre - Posts: 34 |
Hi SC Support, I noticed that on my spreadsheet for trading, the formula recalculations only happen when there is a print in the market (in this case ES) but not continuously. As an example, i have a formula that prohibits trading around the full minute mark +4 seconds, but while e.g. the sizes on the bid/offer constantly change on the chart, the spreadsheet only recalculates and gives new values when there was a print. During GLOBEX hours, it can happen that you do not have a print for 10s or so and that can screw up things for eg realtime stacking calculations. Is there a way to get the sheet to recalculate independently of fills in the market? Thank you for your help in advance. Date Time Of Last Edit: 2025-09-12 07:01:08
| [2025-09-15 15:56:21] |
| Sierra_Chart Engineering - Posts: 25483 |
This definitely should not be the case. We are quite sure, the spreadsheet is going to be updated even with a change only with the bid or ask prices.
| [2025-09-15 15:59:12] |
We have confirmed this is the case. Definitely the Sheet is updating, with bid and ask updates even though there is not a trade. There could not be a problem with this. That really is impossible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-16 08:35:45] |
| Andre - Posts: 34 |
Hi SC Support, You are right regarding bid/ask etc. not sure what was happening on my side. One question remains and that is that e.g. =SECOND(J41) only updates when there is a print. Is there any chance to get the time to update continously? I played around with the Clock - Real Time study to somehow create a work around but was not successful. Thank you in advance |
| [2025-09-17 15:11:45] |
We will add a new field, with the market depth update date time.
| [2025-09-24 20:16:23] |
We did add the new Market Depth Update Date-Time field but it only shows with the new version 2 fields: Spreadsheet Study Inputs: Use Column I and J Values Version 2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-09 15:53:55] |
| Andre - Posts: 34 |
Hi SC Support, Thank you for the J18 field in the spreadsheet V2. Can you make it that the sheet uses the global chart update interval setting (e.g. 10ms)? I looked through the documentation but did not find information on how to change the spreadsheet update interval or what the default is. It seems it is 1 second but it would be great if J18 also updated at the same speed as the chart. Regards, Andre |
| [2025-12-09 18:03:27] |
The Spreadsheet Studies update like any other study, except that only the first 10 rows are calculated and not all rows.
