Date/Time: Wed, 25 Nov 2026 07:56:09 +0000
Problems to config TC1 TC2 etc. for Tool Draw Volume Profile
View Count: 675
[2025-09-10 10:26:05]
User613910 - Posts: 55
I have problems to find logic and understanding to set TC1, TC2, etc.... for the Tool Draw Volume Profile.
If I chose Tools ---> Tools Config ----> Draw Volume Profile Config The only thing I see on the screen is a drop down list with Chart Study Collections. Now what is the meaning of this........?? So for I can not find the logic to set my TC buttons with this.....
Is there a shortcut? That I draw the ideal Volume profile (from the tools menu and set it to my wishes) and program this directly in a TC1...etc... That would make my work much easier.....
Please let me know what I can do...... (see attached the screen with the Chart Study Collections).
Already thanks for your answer....
imageConfig Volume Tool.GIF / V - Attached On 2025-09-10 10:25:12 UTC - Size: 59.03 KB - 244 views
[2025-09-10 11:48:28]
Tr00pz - Posts: 32
All you need to do is create a separate Chart Study Collection for each setup you want then select the collection you want saved to each tool config. I personally have 4 different tool configs that each have separate Volume by Price study collection: Volume by Price - Right, Volume by Price - Left, Delta by Price - Right, and Delta by Price - Left. Each study collection (that contains a different Volume by Price setup) is saved to it's own tool config then when you draw the volume profile, you can right click the drawing and switch between all the different tool configs.
Hope this helps.
[2025-09-10 14:43:40]
Refer to the following:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
