Date/Time: Wed, 25 Nov 2026 07:56:09 +0000
Chart DOM Question
View Count: 607
[2025-09-09 19:31:04]
User940772 - Posts: 85
Is there any way to get a running total of the Bid Size/Buy Column and Ask Size/Sell Column of the chart DOM like that of the Bid/Ask Market Depth Pulling Stacking Column?
[2025-09-09 20:52:25]
There are a number of ways to do this.
First, refer to the following:
Global Trade Settings Windows: Display DOM Depth Totals (Global Settings >> Chart DOM Settings >> Other>> Other Settings)
Moving on from that, the "Bid and Ask Depth Bars" can give you a number of different ways to view the sum of the Bids and Asks. Refer to the following:
Bid & Ask Depth Bars
If you want to just view the sum of the Bids and Asks on the chart somewhere, then use two copies of the "Bid and Ask Depth Bars", one setup for "Sum Bid Side" and the other setup for "Sum Ask Side" and then two copies of the "Text Display for Study" to display the "Close" from the "Bid and Ask Depth Bars", as the current bar's Close gives the current sums. Refer to the following:
Text Display For Study
[2025-09-09 21:25:34]
Thanks John, very much appreciated.
