Date/Time: Wed, 25 Nov 2026 07:56:11 +0000
[Programming Help] - SC ARM version Study
View Count: 478
[2025-09-09 17:56:24]
cmack1011 - Posts: 201
I had a custom study developed for SC, but they did not know how to convert it into a version that will work inside the ARM version (for Parallels/Windows on MacOs) of SC. Can you please provide your recommendation on how I can get this study converted to work inside the ARM version of SC? Thank you.
[2025-09-09 18:04:53]
The developer of the study needs to build it for ARM. An existing DLL can not be "converted". This can be done through our Remote Build option, or if they are building locally using Visual Studio, then there is an option to build an ARM version in there.
